If its fuel the plug would have dried in the air and if its oil it would remain wet. If your not replacing them check all are sparking well. Put the oily one in a different cylinder. Run car up a few times and re visit your plugs again see if the same problem happens on replaced plug. What is the compression on all cylinders. My old 10 valve ng coupe kept cutting out and it was low compression on the rear cylinder. Lots of good advice here but you need to maybe start with the basics first as you don't know anything about this car. Good luck and happy hunting. best wishes Lynn.
Engine stalls right after starting
