Quite nice fuel pump comparison here
https://www.realstreetperformance.co...t-performance/
Big fuel pump comparison
BMW 740iA e38 - Project -
That's quite a comprehensive and detailed test! I like how they did that, and they found some interesting figures there - some of the pumps made nowhere near what the were meant to at 40psi
I was interested to read about the effect of voltages on the pump and can echo this as from recently adding a relay and much thicker power supply and earth wire to my pump, measured flow went up 100ml per minute for free (at no resistance - measuring it coming out of open pipe)
The other thing that article shows is that the horsepower a lot of those pumps are capable of are pretty big power... Standard pumps more than capable of even moderate power increases.
No, I don't have experience with walbro pumps(just have been using lph255 as lift pump to surge tank). Have been using Bosch 044's as pressure pumps.
BMW 740iA e38 - ProjectComment
