Wondering if this will work,
If I used the aby water pump and the aby belt with the cam vernia calipers, will this work?
Would I also need an adjustable exhaust gear
Also 3B block doesn't have the AAN/ABY tensioner holes. But the answer to the question is: Yes, everything can be made to work. It's only a matter of how much effort you wan't to put in it.
