Hello!
a month ago i finished my 20V 7A swap in my car but i have some issues;
1. at cold start it will not run stationary, i need to hold my foot for 5 seconds on the gas and it will stay running.
2. The throthle keeps hanging when i am pulling hard. It does it too when i am driving normally over 4000-4500rpm.
If i switch the car off and back on it is good untill i pull again.
i have faultcode F60 - Leerlaufschalter (short circuit or interrupted)
I have measured the Potentionmeter and it is broken. I ordered a new one at Tradition. I hope this is solved then.
3. Water themperature gauge isn’t working, sensor broken. (035919369L) 4 pins. Not available anymore., Can i use a 3 pins or not? Is it bad if this one is broken?
Oil temperture is 120°c when it is 16°c outside, but i made the wires longer of the oil temperature gauge, Maybe it isn’t correctly on the gauge?
does anyone had similair problems?
