Gurdle mains tourque settings
  • Stealthacq
    • Nov 2015
    • 137
    Hi gents
    Bought a gurdle and the mains have 12.9 bolts
    I have read that people are tourquing them 1/4 turn over stock
    Is this right as seller is specifing std tourque?
    Also do the main caps need grinding down to seat?
  • mac2226
    • Jun 2008
    • 1289
    You should be supplied with shims which will need machining down.
    • Stealthacq
      • Nov 2015
      • 137
      Yes I do have the shims and all the bolts to extend. Just no details with it what so ever.
      • mllen89
        • Apr 2015
        • 63
        75nm with 12.9
        • Stealthacq
          • Nov 2015
          • 137
          75nm and 1/4 turn?
            This is not an simple job to fit correctly, caps need machining, block flange needs skimming parallel with crank axis, spacers need grinding to size. Ideally the girdle plate should be ground flat too. You can’t just bolt it on
            • mllen89
              • Apr 2015
              • 63
              Only 75nm.
              • Stealthacq
                • Nov 2015
                • 137
                Al leave it to the expert. Al pop and see him to see what's invoived and let you know.
                  Hope you got the right expert
                  • rxl
                    • 1913
                    do you need one? i fitted some arp bolts and thats it. for the power levels im going i dont even need that. why do you want to fit it? big power of just becouse it looks nice ? =D
                      I agree. You need to be running some serious power before a girdle becomes necessary. Some "experts" will advise it so you keep them nice & busy
