I'm trying to get my RS2 running, but it's not firing up. Using VCDS I get an intermittant error on the G4 pin on the flywheel.
I've checked the pin on the flywheel and checked the distance from the sensor. It's 0,9mm away. Found online it can be max 1,25mm so should be close enough to trigger.
Also checked conductivity from the wiring from engine bay connector to pin 47 on the motronic 55 pin plug.
Swapped sensors with the G28. After that VCDS gave both G28 and G4 no signal error after cranking it a bit. This was not an outcome I was looking for with this as now both gave an error. It was not clear to me that the G4 was faulty.
Also unplugger the N75 as a test and VCDS picked it up after cranking that is was missing that one.
I found in some documentation that fuel pump relay will not be powered without this signal? correct? I've jumpered the relay and pump runs and fuel rail is under pressure. So I assume these are ready to go but wait for the G4 pulse to come to life.
Also checked G4 flywheel pin with the camshaft sensor. When the pin is at the G4 sensor location the gap for the camshaft sensor is at the sensor. This looks ok to me?
I found that the same sensor is also used on a 7A engine. So Plan for tomorrow Is use that one to have one from a running engine to verify.
Are there any other things what I can check?
