Need help, flame deflector plate. 035103477A
  • aVL1D
    Banned
    • Sep 2016
    • 58
    Need some help with how this should be mounted?
    If you look at the diagram Pic, should I just press it in?
    I'm little unsure about this, feels like it could fall in the oil pan?
    This gallery has 2 photos.
  • Vauhtiveikko
    • Jun 2010
    • 250
    Orginally that deflector is inside the metal tubing after the pressure valve. Mine was in the first bend. Clean those tubes before fitting, lots of gunk inside...
    S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
