Porsche 944 turbocharger hotside mod?
  • 20Vcqdriver
    • 829
    Originally posted by Error404
    My MD357 has a modified K26 turbine housing, I also fitted a larger turbine (60mm IIRC) and shaft at the same time. Will dig out my specs:
    EDIT:
    0.50 A/R GT30 CompCover
    7 Blade 53.10mm Ind 73.00mm Exducer Billet Comp Wheel
    GT30 60mm 84 trim Turbine Wheel
    0.82 A/R Audi Fitment TurbineHousing
    How did it compare to the original 0.6AR MD357 like mine? Boost point, max boost without WOT surge? Cheers
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
      I never had the original spec sorry.
      • twoqu
        • Sep 2003
        • 3103
        Got a reply from the seller on Ebay about the turbine wheel size for this housing:
        Hello, thank you for asking, need to put this info in the listing..
        It is design to fit these part numbers: 5326-120-5002, 5326-120-5001
        Inducer Diameter: 64.4mm
        Exducer Diameter: 54.6mm
        Tip Height: 10.1mm
        So thats the Kontour 1 K26 wheel I think.
        • Kiku
          • Aug 2010
          • 497
          You are right!
