Anyone know the casting #s for the hot and cold side?
RS2 (K24-7200) question
Tags: None
The Turbine housing is basically a #6 casting with a 54.5 exit and the coldside casting and back plate are K26 item's unique to the K24 7200. One can get a stock K24 or Porsche 944 #6 housing machined out to fit the K24 7200's unique turbine wheel/shaft and the same applies to the cold side a K26 housing and back plate can be machined to accept the RS2 compressor wheel, though in the case of the coldside the housing will lack the capacity of a genuine RS2 turbo's compressor housing.
Compressor back plate KKK ID Number... 5326-5799 or 5326-5798.
Compressor housing KKK ID Number... 5326-101-5160.
Turbine Housing KKK ID Number... 53261017388.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
