In the last installment of 'Gasping for air!', I had said that my car would hardly start, and when it did, barely even stay idling. Also, when it idled it was lower than usual, and if I gave it any gas it would die immediatly. So I disconnected the MAF sensor and the idle evened out and I was able to give it gas just fine; but I can't drive it that way, cause then I couldn't run any boost because it would be lean on fuel. Then I plugged the MAF sensor back in and it died quickly. I replaced the MAF sensor w/ a used one, (new probably don't exist any more?) and it does the same thing. Does this sound like another faulty MAF sensor or could it be something else entirely?
Gasping for air 2! The Return
