S6 missing on 2 cylinders
  • audi660
    • Jan 2005
    • 162
    • Country: South Africa
    Hi guys,
    My car is dead on cylinder 3 and 5.
    I've checked all 5 coils and plugs and the spark is good, all the injectors are working too.
    It fires up but if you disconnect injector 3 and 5 there is no difference in idle.
    I'll do a compression test but the motor has only done about 400km.
    Any ideas on what to do?
    [SIGPIC]1997 Ur-S6 SMS Revo S
    You said the spark is good. Have you tried swapping the power output stages for the coils to see if different cylinders are affected?
    • audi660
      • Jan 2005
      • 162
      I've got the 034 coils so no pos units
      • piotr
        • Jul 2012
        • 1470
        How did you tested the plugs ?are you 100%sure that under the load they are producing good spark ?
        Just swap them around and see if the fault is migrating with them .
