RS2 engine mounts
  • npvpositive
    • Apr 2019
    • 57
    • Home: England Current: Australia
    RS2 engine mounts
    I need to replace my RS2 engine mounts. Audi Tradition apparently has OEM mounts, but they're closed for the next few weeks.
    Can I get some advice from more experienced owners? Is there another alternative that is considered equal/better? Ideally, I'd like to keep the car 100% stock, but it's been off the road for several months now and I'm out of patience.
    Nick
    1995 Audi RS2 . . . plus a few other old German cars
  • tango123
    • May 2017
    • 892
    Right Lemforder Engine Mounting 1769701 Fit with Audi Coupe https://rover.ebay.com/rover/0/0/0?m...2F332742712004
    Left Lemforder Engine Mounting 1659801 Fit with Audi Coupe https://rover.ebay.com/rover/0/0/0?m...2F323376946233
    • npvpositive
      • Apr 2019
      • 57
      Thanks Tango. Have you used these Lemforder mounts? Are they effectively the same as the Audi OEM ones?
      Another non-stock option I have read about is the AK Motorsport (now Verkline) engine mount . . . does anyone have any opinions or experience with them on an RS2 or S2? https://www.verkline.com/shop/audi/s...b-aby-aan-adu/
      Nick
      • rustybullethole
        • Aug 2013
        • 531
        I used AK Motorsport for lots of my RS2 refurbishment parts on the suspension and its really top quality stuff, the Lemforder parts are also good and are about as close to original OEM as you will get. Febi are good too.
        • tango123
          • May 2017
          • 892
          As above the lemforder ones are effectively same as oem. I have ordered the ak motorsport ones as the stock ones wont be good enough for what i need.
          • mllen89
            • Apr 2015
            • 63
            Artikelbezeichnung: 8A0399113E & 8A0399114E Audi S2 Typ 89/B4/RS2 P1 2.2l Getriebehalter 6-Gang Links & Rechts Angebot besteht aus: 2 Stück…
            • npvpositive
              • Apr 2019
              • 57
              Those are transmission mounts, not engine mounts. Autewo only have used engine mounts in stock at the moment can't source new ones until Audi Tradition re-opens.
              Nick
              • 90quattrocoupe
                • Nov 2003
                • 771
                I don't how hard it is to get Fox Body Mustang stuff in UK, but Energy Suspension has a trans mount that works as a motor mount on B3/coupes. You may need to elonge a hole and shim down a hair, but they do work.
                Ford Mustang Thunderbird Capri replacement Transmission Mount made by Energy Suspension. 2 Year Warranty. Ships Immediately. Part Number 4.1104_v8
                • rxl
                  • 1913
                  audi tradition shop is open
                    My 2c - you will really regret fitting non-OEM engine mounts - they make the car feel very harsh, noisy & uncivilised.
                    • rxl
                      • 1913
                      yeah that is true =D
                      • npvpositive
                        • Apr 2019
                        • 57
                        I've ordered the Lemforder ones . . . hopefully virtually identical to OEM as per the comments above. I stayed away from the "performance stuff" because I want my RS2 to be a stock street car.
                        Nick
                          Good choice. Lemforder I believe were the OEM
                          • npvpositive
                            • Apr 2019
                            • 57
                            Can I draw on the collective wisdom of the forum (again) . . .. I am getting myself very confused over the different engine mount part numbers:
                            This is what I believe is correct for my 1995 UK RS2 which has air conditioning:
                            Left mount: 8A0 199 382
                            Right mount: 8A0 199 382D
                            There also seems to be a part number that ends in "C" instead of "D". Can someone confirm what the letters mean at the end of the part numbers? Is it right that C means no air conditioning, and D means with air conditioning? Presumably, if I order the wrong one then it won't fit. Or does it not matter?
                            Nick
                            • Nuvo
                              • Nov 2003
                              • 3825
                              The part ending with 382 C is the right hand mount without AC and 382 D is with AC. 8A0 199 381 is the left mount without AC and 8A0 199 382 is with AC.
