Hi, apologies if this has already been dealt with elsewhere. I need to replace the fuel lines on my 1995 ABY S2 - corrosion advisory on recent MOT, but now leaking. Have spoken with various people who have suggested using 8mm copper central heating pipe and 8mm compression fittings. Pipe and fittings now purchased and ready to start. I am intending to replace as much of the existing pipe as possible. I have noticed that there are 3 pipes running from engine bay to rear all clipped together with the original clips which harbour water leading to corroded pipes. My question is are all 3 pipes fuel and if so, what are they all for ? I accept that 2 will be for feed and return, but what is the 3rd line for (assuming it is fuel) ? I will be removing the protective shields tomorrow so hopefully will have a better idea.
Thanks in advance for any advice.
