Engine belt alignment question
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    Hello
    Here is my question.
    I have an rs2 setup, ie rs2 cambelt, rs2 camshaft sprocket, rs2 water pump.
    However I have a 3b block. So if I use a 3b oil pump and water pump whilst I change the water pump bearing with the rs2 one, will be able to align the camshaft markings to the rs2 setup this way?
    Thanks
    PS reason for going this route is to avoid drilling the 3 M6 bolts to fit the rs2 belt tensioner as I'm trying to avoid drilling into water channels on the block. Has anyone done this before and if so, is it safe?
