Hi guys, been working on this S4 and it's fitted with MAC 3 Solenoid valve which replaces N75. Does anyone know correct way to fit it?
MAC 3 solenoid
Yes fella you have a in and an out. The one on the front is a exhaust (Vent to atmosphere) The right and left are air in air out. You can check in and out by blowing in to one side and pushing the little button on the top. The air should pass through the mac valve if not blow the other way and double check its passing through Sorry, I hope that makes sense.
