so i am building the plug and play adapter for the loom on my 7a (no i am not buildding a full engine loom before it is said) but i am having a bit of trouble figuring out how to connect a few of the sensors manly the knock and crank snensor i thoght id ask for some help on the matter as im not sure what to do?
here are the info on the ecu pins i have if anyone has a better pin out for the 2 block 7a ecu it would probably help as well and the aftermarket ecu is the emu black
yeah, what do I know.
