Custom radiator
  • simons2
    • Mar 2010
    • 344
    I had my main and aux rads made by Custom Made Rads in Nottinghamshire , excellent quality
    • QuattroFever
      • May 2006
      • 1360
      These guys are great as well. Little bit pricey but they have all sorts of options.
      They might still have my old ABY radiator there as a pattern to make up one for someone.
      It is worth remembering that a third of the engines power can be converted into heat energy and any increase in engine power from tuning will result in an increase in heat output that will need to be accommodated by the cooling system. A rule of thumb; 30% more power output equates to 30% more heat output. Aluminium radiators can provide over 30% more cooling and are often 40% lighter than traditional copper and brass radiator construction.
      Volcano ABY coupe
      Ant
