After Some Advice For The Aby S2, It Has Developed A Slight Miss , I Was Going To Change The Plugs, But How Do You Get To The? And Also Does Anyone Else Know Of Other Common Problems That Can Cause A Slight Missing.
AFTER SOME ADVICE FOR THE ABY S2, IT HAS DEVELOPED A SLIGHT MISS , I WAS GOING TO CHANGE THE PLUGS, BUT HOW DO YOU GET TO THE? AND ALSO DOES ANYONE ELSE KNOW OF OTHER COMMON PROBLEMS THAT CAN CAUSE A SLIGHT MISSING.
To get to plugs remove the plastic cover at the top of the engine (2 screw fasteners), prise it off...and voila....you will be able to see the plugs at the bottom of their chambers.
I would think you should test all the coils as this could be your problem "possibly"
if you can identify which cylinder is missing. Swap a coil from a known good cylinder to the bad one...and bingo,...your dodgy coil will be ID's when the mis swaps to another cylinder.. hth
Ain't no shoddy plastic cover on the ABY you know !
The ABY has an alloy top cover on the cylinder head which is held on by 2 or 3 hex fasteners.
The plugs could be loose - very common.
Also suggest you check earth strap on rear of cylinder head.
COuld be a faulty coilpack or POS unit - they can be juggled and rewired to make use of a spare circuit if you aren't afraid of working from a schematic !
