rings for 80.98 piston
  • rings for 80.98 piston
    Hi, what is the size of the rings for the original 80.98 pistons?
    Step 1: setup. <==
    Step 2: potentiation.
    Step 3: enjoy.
    Standard size. The bore should be 81.01, so the rings are that size minus their end gap which is 0.3 or 4 from memory.
    Top ring 1mm, 2nd ring 1.5mm, oil control ring 3mm.
    91 Modded 3B
    14 A6 Avant Black Edition
      No need for that big ring end gaps? 0,45mm first, 0,50mm second, 0,40mm oil rings. Very good for motosport use, and still some wear reserve, and should be zero oil cosumption.
        It was ring thickness I was providing, not end gaps
        91 Modded 3B
          Aah, ok
