Large IC install/pluming
This is a sticky topic.
    replied
    Originally posted by 4WheelDrifter
    I'm with Roger on this one too.
    Each to their own on this one, I not up for a ruck today
  • T2Andy
    replied
    These are indeed correct m=53 lb/min, Cp=0.25, U*A=20.1
    lets start by assuming that the intercooler outlet temp = 140
    Q = m * Cp * DT
    Then DT = (350 - 140 ) = 210 and Q = 2782.5 BTU/min
    Cooling air flow = 85.33 lb/min
    DT for the cooling air = Q/(m*Cp)
    DT = 2782.5 BTU/min / (85.33 lb/min * 0.25 BTU/lb-f) = 130.4 F
    since DT = T out - T in, then 130.4 = T out - 85 and T out = 215.4 F
    So the cooling air inlet is 85 F and the outlet is 215.4 F, and the turbo air inlet is 350 F and the outlet is assumed to be 140 F. Now calculate DTlm:
    P=0.792, R=0.62, and F=0.75
    DT1=134.6, DT2=55
    DTlm=(134.6-55)/ln(134.6/55) * 0.75 = 66.7
    Now calculate a new Q, Q= UA * DTlm
    Q=20.1*66.7=1340.7
    Since this isn't the same Q we got when we assumed an outlet temp of 140 deg, we have to get a new outlet temp and run through all this again.
    I'll assume a new intercooler outlet temp of 170.
    Q=(m*Cp*DT)=2385
    cooling air DT = 2385/(85.33*0.25) = 111.8
    Cooling air outlet = 85 + 111.8 = 196.8
    P=0.68, R=0.62, F=0.84
    DTlm=97.3
    Q=1954.7 still not close enough
    Last try!
    T IC out = 182
    Q=(m*Cp*DT)=2226
    cooling air DT = 2226/(85.33*0.25) = 104.4
    Cooling air outlet = 85 + 104.4 = 189.4
    P=0.63, R=0.62, F=0.88
    DTlm=111.0
    Q=2232 close enough SPOT ON
  • terrybullwon
    replied
    Good one
    Heres a very interesting read Intercooler read
  • 4WheelDrifter
    replied
    Originally posted by Audi_CQ
    No you don't get a pressure drop with a large IC. A too small one would get you a pressure drop.
    A large one will give you a bit more lag (because there are a little bit more volume to fill), but no drop in pressure
  • s2_bo
    replied
    Hmm, i think you scored on that one Roger..
    I don't really know enough about it to join in in this debate, but you certainly convinced me
    Nice IC BTW
  • Audi_CQ
    replied
    Originally posted by terrybullwon
    I think your find Jamo is right here,
    eeeehhhhh, no
    You are right about the lag as the turbo is going to have to fill the volume of the intercooler.
    Agree
    You really want a intercooler that will maximise cooling efficiency, minimise pressure drop. So to small is going to be usless any way!
    Agree
    Right air from the turbo is passed through core allowing heat to dissipate. The larger the core area the grater the loss. But equally a lager core will cool more air. (you need to create a equal medium)
    Not 100% sure about "equal medium". Thinking about cross section of the IC?
    resistance of a standard one could be say .05kg/cm2 at 1.2kg/cm2 of boost but the larger you go the bigger the drop.
    Here I don't follow you
    Lets look at IC's as pipes: Would you say that a small pipe has less resistance then a bigger one?
    About drop you got it right in that the pressure will drop, but not because of resistance. As the air cools it gets denser and takes up less room. Pressure drops, but amount of air is the same. This is the IC's main function
    Also you have to add the resistance of the pipe work.
    Hense reverse inlet manifolds
    ( ,but the pipe resistance would be the same independent of IC size... )
    Originally posted by s2dude
    Can you explain how you came up with this "theory" Roger?!!! Jamo is correct!
    I'll try:
    The turbo will deliver about the same amount of air independent of IC as long as the IC isn't so small that it becomes a major restriction (cross section inside IC is much smaller then other pipework) Agree?
    The turbo will deliver most air when the resistance is as small as possible. Large short pipes and IC's with large cross section has the smallest resistance for a given amount of air. Agree?
    (Going too large on pipes and IC's would of course at the end be giving more lag then the gain in smaller resistance could justify)
    When the turbo deliveres the most air it will also deliver the highest pressure in the inlet manifold. Agree?
    So as earlier said the only pressure drop a large IC will create is that as the air cools it gets denser and takes up less room and the pressure drops. The amount of oxygen would be the same, but in a smaller volume and therefor making it easier to get the oxygen into the cylinders. This is the IC's main function
    Was that understandable or.... ?
    Cheers,
    Roger
    PS: This is my IC:
  • adamw
    replied
    just a small question... would the ic be more efficient if it was longer rather then taller? as u would get more air passing more of the ic? it made me think because half the ic is getin blocked by the bumper/ number plate.
  • terrybullwon
    replied
  • s2dude
    replied
  • Audi_CQ
    replied
    Originally posted by Jamo
    Pressure drop, when fitting a larger intercooler there's more air space to fill inside it by the turbo charger. If the turbo can't fill it quick enough over the pipe length / volume space you get a pressure drop.
    Hence my mantra you can have too big an IC.
    replied
    The stainless pipe is 3mm thick? Thats pretty heavy. Can you get thinner stuff? 1.5 or 2mm should be plenty thick enough, I would think.
    I'd like to order a crossmember if you're thinking of having some made
  • travill
    replied
    http://www.s2forum.com/photoplog/ima...0__Medium_.JPG what you see in the picture intake mainfold I would liket to buy one, could you be so kind to help me in this matter?
    replied
    too big why would it be too big?
    Bo is going to RS2 setup though so it's needed.
  • Audi_CQ
    replied
    Originally posted by s2_bo
    I used to get 1.4 - 1.45 bar and now its peaking at about 1.35
    I think the IC is to big for the K24 - good thing that i'f got a K26 on the way
  • s2_southwest
    replied
    Ok dan look forward to that!!
    Finetubes @ estover would be a good place to get some ally tubing, nice and lightweight!
