Oil warning light
  • bilko0795
    • Feb 2011
    • 1883
    Oil warning light
    As per title the warning light is flashing on intermittently I know the car is full as I did an oil change 2 months ago and the car hasn’t moved until yesterday the oil temp is good so is the pressure so I’m thinking oil pressure sensor faulty or is there another sensor I need to check. The car has had a complete Engine gasket and sensor overhaul but I don’t know if the guy changed the oil sensor.
  • bilko0795
    • Feb 2011
    • 1883
    Just found the thread on this problem
    • Bowie69
      • Nov 2013
      • 2675
      There are many!
