Head Gasket can of worms??? - Now chasing Boost Leaks!!!
It is also worth checking your PCV for leaks Steve, that has caught me a few times in the past -
I have some ordered new inserts from Alex (Error404) so will get this done soon.I had to replace all of the pink inserts on my injector connectors after constantly chasing random misfires and a lumpy idle, like John I used second hand ones from old connectors I'd cut of old looms prior to scrapping them, they're not just used for the injectors I managed to find five from bit's of various VAG looms. This was on my old 3B, the one's on my RS2 still seem to be fine, though that car has covered half the miles.
SteveLeave a comment:
I had to replace all of the pink inserts on my injector connectors after constantly chasing random misfires and a lumpy idle, like John I used second hand ones from old connectors I'd cut of old looms prior to scrapping them, they're not just used for the injectors I managed to find five from bit's of various VAG looms. This was on my old 3B, the one's on my RS2 still seem to be fine, though that car has covered half the miles.Leave a comment:
Hi John, yes replaced all the hoses and clips down there. I am going to re-run the boost leak test at the weekend to see if I can find it.
If you haven’t already done so take the headlight out.
DV is tee’d in down there, and DV to MAF hose.
Then there’s the nipple on the turbo going to the N75.
Turbo outlet can be tricky to tighten and is often oily and rotten but as you’ve had the head off I guess you’ve gone silicone hose?
It is boosting more now, but it still tailing off under high load....
Stay tuned!
If you haven’t already done so take the headlight out.Thanks Greg!
On a side note, I am now chasing boost leaks as the old girl is not as spritely as I remember.
One found on the short cam cover breathe hose, but it is still not holding boost. I can hear it coming out around the entry to the intercooler....
I will get there in the end!
Turbo outlet can be tricky to tighten and is often oily and rotten but as you’ve had the head off I guess you’ve gone silicone hose?Leave a comment:
Thanks Greg!
I''ll add the injector wiring to my list of jobs as I occasionally get a lumpy idle. Its nice to see both motors up and running and on your drive
I got mine from an old wiring harness using plugs that hadn’t got hot over the engine so we’re in good condition.
Yes you need a pin extractor, I’ve got a cheap set and a couple of proper ones (but you can do it with a paperclip once you get the hang of it). The plugs are called Junior Power Timer or JT. Alex can supply genuine ones I think, or eBay which seem to be copies (or maybe they don’t make them the same as they used to.)Leave a comment:
Well done, good work!
I replaced all the inner pink bits on my injector plugs as they were all starting to break up.Leave a comment:
UPDATE!
Well it has been a while hasn't it! Life goes on and gets in the way of things, however slowly but surely I have worked through this list over the last 10 months:- Fuel completely drained and repaced - Same (New fuel pump and fuel filter whilst I was at it!)
- New POS Stages fitted and spliced into connectors - Same
- Replaced all 5 Coilpack with brand new ones (was on my to do list anyway) - Same
Once this was fixed the car still had a lumpy idle which I traced to a disconnected hose on the cam cover.
This week the S2 passed its MOT with No Advisories! Not bad for 29 years old and 190,000 miles!
My Audi fleet is now working and complete!
PXL_20220803_100541545.jpgAttached FilesLeave a comment:
The pump needs to be "on" for the fuel to emerge from the tank. This was indeed my original plan.
I have a new fuel pump to go on, so will do that and probably drain the tank from there whilst it is out.....Leave a comment:
Is is not possible to just pull one of the rubber lines to the fuel filter and drain from there or does the pump lift the fuel to get there anyway?Leave a comment:
