Boost dropping - 1.7 Bar -> 1 Bar
  • Vilhelm
    • Nov 2006
    • 75
    • Home: United States Current: Norway
    I get full boost at around 4000 RPM, but the boost drops slowly all the way to redline. At redline it's only boosting 1 Bar. I also get a "kick" from 4000 RPM. Nothing really happens between 3500 and 4000 even though the turbo is boosting over 1 Bar @ 3700. What can this be? There is another guy at the vwaudi-club forum that has the same problem - S2 with almost identical mods. He is running 1.2 bar though and it is dropping to 0.6 at redline.
    Any suggestions?
    TIA,
    Vilhelm
    Audi A8 w/ RS2 engine. 520HP @ 1.8 Bar.
  • Vilhelm
    • Nov 2006
    • 75
    Anyone got any suggestions?
    • topsparky
      • Oct 2005
      • 2014
      have you done a boost leak test??
      1. SHORT SHIFT KIT
      2. PORSCHE CAYENNE CALIPERS
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      5. NEW BUSHES AND HP2 STRUTS
      6. UPRATED HIGH OUTPUT COIL PACK
      7. ,3" turbo back s/s/ exhaust
      8. fmic fitted
      • prosty
        • Jun 2005
        • 1114
        What WG spring are you using? Try a harder one, a 1.2 or 1.4 bar boost spring.
        2004 9-5 aero
        2009 Subaru Legacy Diesel
        1994 Toyota Supra Eurospec 6-spd LHD
        3-4 Audis in parts
        • Vilhelm
          • Nov 2006
          • 75
          yeah Jonus is gonna get a WG spring for me. I found out that my diffs don't work. I was spinning on one wheel even though both my diffs were activated. So can the diff system be leaking air and cause boost to drop up top?
          • prosty
            • Jun 2005
            • 1114
            That seems like a long shot , just check the vaccum lines from the intake, a purple plastic line going into the firewall, that's the diff. If it's broken, there's the problem (of the diffs) but see what the spring does first.
            2004 9-5 aero
            3-4 Audis in parts
