Oil dipstick tube
  • pfi
    • Jun 2016
    • 274
    • Country: Norway
    Oil dipstick tube
    Having trouble removing dip-stick tube
    what's the trick ?
  • SteveH
    • 4460
    What motor is it 3B or ABY/AAN? The 3B tube goes directly into the block and the later cars have an adapter which is in the block. Both can be removed with a suitable size drift from the bottom of the block.
    91 Modded 3B
    14 A6 Avant Black Edition
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      It is 7A block, also has an AAT, no one has adapter ...
      Have tried hitting (pretty hard) from the bottom but no movement at all, just have to hit harder then ...
      • SteveH
        • 4460
        I used a decent sized lump hammer and a drift which just fitted the hole in the block. You could soak the outside with penatrating oil too.
        91 Modded 3B
        • pfi
          • Jun 2016
          • 274
          • Country: Norway
          yea, suppose it's important with a proper matching drift ... the one I used was propably to small ...
          I'll soak it with wd40 and find a better drift
