SM Flywheel
  • pfi
    • Jun 2016
    • 274
    • Country: Norway
    SM Flywheel
    I have a 035105271P flywheel but it does not show up in ETKA
    It looks identical to 035105270B FW used on WR/GW/WX
    problem is it's doesn't have a "mount" for the pilot shaft bearing, suppose there must be a sort of adapter that goes in the crank but can't find a part# in ETKA.
    anyone knows ?
    The pilot bearing is fitted in the crank
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      directly in crank, no adapter ?
      Plan was to use the FW on AAN in B3 with 7A 5-speed gearbox, will the shaft from gearbox be long enough to match crank-mounted bearing ?
      • _ShurikeN
        • Mar 2010
        • 733
        • Country: Russian Federation
        No. You better need FW designed for 01A/01E transmission, not yours 016-flywheel.
        For bolt-on solution you need to buy S2 3B or 7A flywheel. You can also use flat NG/AAR flywheel or deep-dish style one from early AAH or AAT.
