Draining Tappets
  • Stefen
    • Jun 2010
    • 103
    Draining Tappets
    Hi,
    Just looking for some advice on what is the best way to drain the tappets on the AAN engine. Thanks.
  • SteveH
    • 4460
    With the lifters out of the motor?
    91 Modded 3B
    14 A6 Avant Black Edition
    • Stefen
      • Jun 2010
      • 103
      Yes.
      • SteveH
        • 4460
        You can dismantle the lifters to clean the valve section on the underside. It's easy to flush them once this is removed. You can dismantle the hydraulic components to clean them. It's a bit fiddly, but not too bad. To remove the hydraulic shim, repeatedly tap the lifter on a block of softwood. The valve section will drop out. A few short, sharp shocks should do it. This is generic but should help https://www.youtube.com/watch?v=5_feG-bfSPs
        91 Modded 3B
        • SteveH
          • 4460
          Dont forget to fill them before putting them back in! They will be noisy at first until they have pressurised.
          91 Modded 3B
          • Stefen
            • Jun 2010
            • 103
            Thank you kindly.
