No boost
  • No boost
    Took my S2 out tonight for the first time in about 6 weeks, it last ran perfectly.
    For some strange reason I now have very little boost. My gauge is showing about 0.5 bar. Had vagcom in the car while i was out and read the codes there were 4 i think. So cleared them, drove off and had full boost in second gear, changed to third no boost.
    Checked the codes again when i got home, they are;
    00540 knock sensor
    00513 engine speed sensor
    Have checked the MAF sensor connector/plug and the WGFV connectors all fine.
    Anyone have any ideas?
    I think (not sure) knock will reduce boost.
    Had something similar happen after rebuilding my engine which I solved with cleaning the knock sensor connectors behind the engine.
    Might be worth a try.
    Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
    http://www.garaget.org/?car=52877
      I’ve had a knock sensor failure before it cuts boost, can come back when switched off and back on. They are a bit akward to get to
        Found the problem.
          Wheres the best place to get a
          new one?
            That autodoc seems to do a few
              Thanks Andy will have a look there now.
                Bought both of mine recently from bosch
                  Yeah be careful with autodoc, i know other members have had some issues with orders. Bosch dealers should be able to help you though
                    Got a new knock sensor from motorparts direct in the end for £38. Fitted it and problem solved. Back on boost
