Oem part number
  • Oem part number
    Trying to find the oem part number on the gaskets for 034115417C oil filter holder.
    The big and the small gasket.
    What size are the threads on the holder for the oil to go in and out ?
    Best regards
    They dont have the gasket on Audi retailer.
    This gallery has 1 photos.
      The gasket between the filter holder and block is 035115441B but not sure what you mean by small gasket as from memory all the other seals 1n the holder are via o-rings, although it is a long time since I was down and dirty with my car
      Cheers n
      Si
      Subtle mods here and there
      2011 A5 3.0 TDi - Lava Grey
        Do you use gasket or liquid sealing ?
          There is a o-ring under that lid. Have a look here: http://www.oemepc.com/audi Yes, the advertising i awfull.
