Hesitation
    Hesitation
    Looks like ive got a little problem on my S2 now, on boost it has started to hesitate a bit as the boost comes in. Been wondering if it could be a boost leak or if the map needs adjusting on it.
    Peak boost went upto 1.97bar norm upto 1.8-1.9bar.
    Only thing I can think of that might have done it was the accelerator cable had stretched a bit and I re adjusted the cable with the clip on the throttle body so might be getting more WOT now.
    Depending on how the maestro has setup temp compensation for your boost curve, you just might be getting more boost cos of baltic air temps recently and that is enough extra that you can feel the hesitation from the timing being retarded as result perhaps. Very hard to say... I would wait and see if the behaviour persists if the weather warms up a bit.
    Doubt you are getting 'more' WOT than before - its either WOT or its not !
    • YELL MAN
      • Dec 2005
      • 535
      • Country: Shetland Islands
      What does WOT actually stand for i have been trying to figure it out for a while now
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
      • LHD_Kid
        • May 2006
        • 3695
        Wide Open Throttle
        • YELL MAN
          • Dec 2005
          • 535
          Cheers for that. Thinking about it was begining to hurt the grey matter
          1953 AJS Model 18S
            Think I'll have to give MRC a call and see about a check over in march
            • nigelm
              • 150
              hesitation
              Just be sure not to miss a loose spark plug.
              nigelm
                Lambada sensor? Was the cause of some hesitation on mine at full boost. Showed up as an active map control or active mapping error on an ECU check.
                  nigelm
                  good point, will check that, just had head repaired because of that
                  • NoNonsense
                    Forum Sponsor
                    • Apr 2004
                    • 673
                    sounds like it could be a boost leak to me. how is your fuel mileage?
                    Joe "NoNonsense"
                    axis motorsport
                    joe@axismotorsport.com
                    "At the end of the game, the king and the pawn go back in the same box."
                      I found the problem and fixed it today, after waiting for some parts. spark plug 5 was upto its neck in oil because of the camcover seal
                        And I also had to fish the bits of rubber from around the cams
