1st speed on radiator fan
  • Slim m
    • Jun 2006
    • 104
    I have a problem! my first speed on the rad fan is not going off! at all!! so im having to pull out the fuse! can anyone help? (its an s2 3b) Liam.
    Welsh back lanes are the best!:mischeif:
  • john881000
    • May 2004
    • 598
    fan
    hi
    just a thought
    the electrical plate where the fan wires go onto could be faulty
    normally sits under car near brake bomb on left side of engine bay......sitting in drivers seat
    or radiattor fan switch.........
    my 2 cents
    cheers
    john
    • shortsport
      • Dec 2006
      • 186
      Could be coolant temp sensor,I know later Golfs suffer that problem.
      • Slim m
        • Jun 2006
        • 104
        electrical plate?
        Originally posted by john881000
        hi
        just a thought
        my 2 cents
        cheers
        john
        Im not sure what you mean by electrical plate! Also do you know which sensor is for the first speed? Liam.
        • raymor
          • Sep 2003
          • 597
          I've just had that... and the relay was faulty. Can't remember which one and it's too cold to go out but it's clearly marked on the relay/fusebox. £1 from the scrappy... a snip.
          1997 A6 (C4)Q TDi http://forums.tdiclub.com/showthread.php?t=291269 - Sold
          1987 CQ85RS
          1994 S2 Avant- Gone
          1991 V8 -Gone, but lives on in the TDi and CQ
          Fintray Hillclimb - 33.20s
          Doune Hillclimb - 55.02s
          Forrestburn Hillclimb - 52.61
          • Slim m
            • Jun 2006
            • 104
            i have a 3b! mite this be different to the aby? Liam.
            • terrybullwon
              • Mar 2006
              • 8782
              The part number for the relay looks like its the same for both cars 8D0 951 253A
              Position 6
              Chef
              • raymor
                • Sep 2003
                • 597
                The relay I pulled as a replacement was out of a standard A80... and I've just checked it's numbered as 214 on top of the relay itself and is clearly marked as 'radiator fan speed 1' (IIRC) on top of the cover.
                ... it is indeed freezing outside
                1987 CQ85RS
                1994 S2 Avant- Gone
                • Ski
                  • 2591
                  Anyone know where such a relay can be located in UK ? euro car parts?
                  ABY Coupe
                  • Slim m
                    • Jun 2006
                    • 104
                    Thanks for braveing the cold for me! Much appriciated . My relay is marked the same, but is this the part number? Liam.
                    • Slim m
                      • Jun 2006
                      • 104
                      Position 6
                      Is the part number printed on the relay itself? Liam.
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        I have not looked, i just used the family album. But audi are good to us by putting a part number on ever thing they can
                        Chef
                        • john881000
                          • May 2004
                          • 598
                          HI
                          after looking on above posts i pulled my relay out of spares
                          on my relay 214 i have following part numbers
                          443 951 253k it seems like a basic relay
                          on http://www.s2-audi.co.uk/tech_articl...lay_pos_13.htm
                          OR
                          looks like it says relay must be 217 partno 443951253s /357906381b
                          another is the cooling pump and rad fan stage 1 control unit partno 447965571a
                          THIS ADDRESS IS ONLY ONE I COULD DECIFFER FROM OLD WORN PAGES.......................... NEED TO FEEL AROUND THE SITE.......SORRY
                          hoping i understood info correctly and this helps
                          cheers
                          john
                          • dub007
                            • Dec 2006
                            • 29
                            I think the others are right with the relay being bad. I’m pretty sure it is just a very standard 40-amp relay. Hopefully your fuse box looks like this one, I don’t know how much variation there was. You can swap over any of the other 40 amp relays already in the car to check it. The one for the a/c should be the same. Just get a cheep 40-amp relay. As long as it plugs in and is a 40amp your set (The switch in the relay is between 30 and 87). If you try to get one from Audi they will charge you way too much.
                            the fuse box-
                            hope this helps
                            • Ski
                              • 2591
                              excuse my guys, but would this do the trick?
                              The UK's electronics specialist. Free UK delivery on orders over £35. Explore our extensive selection of tech essentials including batteries, cables, PC & mobile accessories, cameras, audio equipment, electricals, and security tech. Visit us today!
                              ABY Coupe
