Lower coolant hose aux radiator delete
  • Lower coolant hose aux radiator delete
    Hey guys i am after one of theseHey guys, im after a lower coolant hose that deletes the aux rad connection. Did the standard coupes have this as standard?
    im after either a samco / modified hose or a standard oem hose.
    Does anyone know where to get this or what it is called so I can search correctly for this.
    Im trying to do the aux rad delete and so far have dangley bits of coolant pipes currently.
    thank you
    audi 4000 hose (in the usa)
      You need 893121055b.
      Available at Audi Tradition
      Nothelle S2 Avant in restoration
      Wr Ur Quattro (also in restoration)
        Huge thx duders!!!
          Just found a cheaper one 2nd hand on google! Whoop, bought delivered 30euro from Germany. Thanks so much x
            Did you check Audi Tradition? May be a bit late now but I paid 44 Euro last year
              Hmm . so this hose takes away the original hose , if you dont use the extra cooler in front ,, correct ?
                Correct, you want to use the lower B2 Audi 80 (4000)quattro radiator hose, it may need some trimming on the thermostat outlet. try searching for Radiator Coolant Hose-Molded Radiator Hose Lower Continental Elite 61508
                Peter S
                1990 ErsatzS2 - track toy
                1991 Coupe Quattro
                1991 Coupe Quattro
                1995 S6 Sedan
                1995 S6 Wagon
                  If you use the 7a hose I listed above its a perfect fit, no trimming required. And yes, removes the bottom branch for the Aux.
                    Yes correct xx
                      So this goes from the hose on the front in the bottom of the big radiotor to the thermostat ,, correct ?
                        It should do yes
                          I have silicon hose ,, new ,, that has the extra hose to front aux. I want a hose without it .. 893121055B ,, somebody that want to make a change with me ?
