Ring end gap Mahle 2020
  • Ring end gap Mahle 2020
    Hi.
    I am just gapping new mahle pistons. 81.51, 0.06mm bore to wall. if i look at mahle 2020 chart. top an second same gaps
    quite big gaps vs oem
    what do u think should be right gap, 600-700 hp.
    This gallery has 1 photos.
    You certainly need a larger gap for that sort of power. Better to have some gap than have them pinch up. I would go with their specs since they will have tested them.
    91 Modded 3B
    14 A6 Avant Black Edition
      i know i need som extra gap. think i will go for 0,0062" pr bore " thats around 0.5mm top an second ring. does i sound crazy ?
