Audi S2 3b rough idle
  • brelum1
    • Dec 2015
    • 34
    • Country: Norway
    Hello,
    i have a problem with my s2, its running bad on idle and givs fault code 00537 adaptation limit exceeded.
    Anyone had these problem before?
    This gallery has 1 photos.
  • ristokru
    • Oct 2016
    • 270
    My problem was ISV. Check this.
    • nick
      • Oct 2020
      • 35
      • Country: Belgium
      Same here,disconected the idle valve and immidiately it setteled,cleaned the valve and idles perfect now.
      Also check the vacuum hoses behind the valve,i found 2 who were brittle and probably leaking.
      • brelum1
        • Dec 2015
        • 34
        • Country: Norway
        Hello,
        i found the problem, it was bad o-rings on the injectors, when i changed this the var was fine.
