adjustable chain gear
  • tango123
    • May 2017
    • 892
    just wondering if i need the adjustable chain gear for both cams or just one?
    cheers for the help.
  • rxl
    • 1913
    only one but if you want to get the benefits out of both you need also a cam gear.
      /\ Yes, you only need the adjustable sprocket on the intake cam.
      Exhaust cam is adjusted using an adjustable pulley, the intake cam angle is adjusted using adjustable sprocket.
      • tango123
        • May 2017
        • 892
