Hello guys! So i need some photos please if some one can take it
Today Im commenced to fit timing belt on my stroker engine 2.5 with diesel block,BUT i met the following problem:
Crankshaft pulley is align on the mark, belt is the standard AAN 151 tooth with custom tension bracket and standard AAN pulley belt. Both camshaft are correct align and as all know its appear some miss align on camshaft sprocket, which is original AAN unit. I need some photo please on standard AAN engine where is the shutter window for G40 sensor when is align on the marks .As you can see the miss align as per the attached photos:
Today Im commenced to fit timing belt on my stroker engine 2.5 with diesel block,BUT i met the following problem:Crankshaft pulley is align on the mark, belt is the standard AAN 151 tooth with custom tension bracket and standard AAN pulley belt. Both camshaft are correct align and as all know its appear some miss align on camshaft sprocket, which is original AAN unit. I need some photo please on standard AAN engine where is the shutter window for G40 sensor when is align on the marks .As you can see the miss align as per the attached photos:
