3B Timing Chain question
  • Crasher
    replied
    Please someone delete the extra posts!
  • Crasher
    replied
    Sorry for the delay. You have to lay the chain in place and fold it over the cams with them in the correct position. On this engine, I used POGO vernier sprockets to dial the cams in perfectly.
  • Crasher
    replied
    Sorry for the delay. You have to lay the chain in place and fold it over the cams with them in the correct position. On this engine, I used POGO vernier sprockets to dial the cam is perfectly.
  • Alex20v
    replied
    Originally posted by Crasher
    The easiest way is by using the Febi 25400 split link and length chain.
    Hi Crasher,
    With your solution using the split chain, can I rotate the camshafts without lifting them? I’m currently not sure if there’s enough clearance between the camshafts and the cylinder head.
    And can I simply pull out the old chain and add the new one without the camshafts rotating, or is there not enough clearance for that?
  • Crasher
    replied
    Originally posted by K Simmonds
    As far as I'm aware one has to lift the cams out to remove the chain, there is no split link.
    Edit... Just read back through the thread, there obviously is a split link on replacement Febi chains, I've not seen one on any of the OE chains I've handled.
    They offer both.
    replied
    You could cut out a link with a grinder using a thin disc but you would have to protect everything with clean rags to stop any metal participants getting into the engine. I would set to TDC before you start and remove the spark plugs to prevent pistons creeping with compression.
  • K Simmonds
    replied
  • pscouto
    replied
    Yes, that is what I am doing in the picture. This chain saves the stress of the cams in/out and worrying about breaking a cap. On this job, I was using POGO vernier sprockets and belt pulley so I could set the cams dead on spec, the OE set up would have been 1.35 degrees retarded.
    Just a quick amateur question, how do you remove the old chain without removing the cams?
    replied
    I had a good look at the Febi chain. They are manufactured by JWIS in Germany. Not sure if they are OE suppliers? Febi seem to be more of a box manufacturer these days.
    replied
    I have fitted a few of the febi chains no issue. Compared to the original audi chain, they look identical.
  • John.
    replied
    I have been professionally using FEBI for 40 years and the problems I get minimal....
    That's good to hear your experience of them is good. I use their stuff now and again and never had any problems.
  • Crasher
    replied
    Yes it is running. I have been professionally using FEBI for 40 years and the problems I get minimal, their KR 16v timing chain (which is the same) I have use since the late 80's when we started doing Golf 2 16v head porting. Their lifters are INA and better than VW, they never rattle, this particular cam chain, which I used to use in the old continuous link way, is vastly superior to the VW part, never exhibiting the looseness a VW one will from low milage. FEBI products are nigh on the best I know, the only company who sometimes does it better is Meyle but their UK importer is not very proactive.
  • Alex20v
    replied
    Nice to know, did you already run the engine with this chain?
    Febi unfortunately often has inferior quality....i don't trust the whole thing
    replied
    Nice. Thanks.
  • Crasher
    replied
