Sparkplug wires and connectors
  • S2_avant 19930325
    • Mar 2019
    • 648
    Does anyone know what the metallclips/connectors has for "number" , what to do my own cables for another car . i have msd wires and the rubber connection , need only the clips .
  • LSG
    • May 2010
    • 897
    The metal clips ? Plug or coil end. How many do you want. Can you post a photo.
    • S2_avant 19930325
      • Mar 2019
      • 648
      I need plug and coil end . at the coil end i need the clip for M4 thread and it should be bendable at coil end if you use like 9o degress to coil.
      I need 15 each, total 30.
      Best Regards
      • LSG
        • May 2010
        • 897
        We use them on some off the turbo busa jobs but i dont think i,d have 30 spare. Why so many ???
        • Bowie69
          • Nov 2013
          • 2675
          You can get the connectors on ebay very easily:
          https://www.ebay.co.uk/itm/10-each-s....m46890.l49286
          (not necessarily the right ones, just an example)
          • S2_avant 19930325
            • Mar 2019
            • 648
            Best Regards
            I want to make new igniton cables , for 2 of my cars ,, 6 cylinder bmw.
            But after checking i need 4 wires , that i have. And the clips in both ends for 8.5mm cable.
            The rubber housing i will reuse.
            • S2_avant 19930325
              • Mar 2019
              • 648
              But when you look for 8.5 mm connectors you dont get so many choices , pretty expensive.
