Hi all,
Going to be fitting a new set of valve seats and valves into an ABY head. Thinking I may as well go oversized as its a high power engine. I'm looking at valve seats from Serdi (https://www.serdi.co.uk/engine-compo...-seat-inserts/)
I was thinking to go 1mm bigger on the OD and 1.5mm on the ID (making the wall thickness of the seat slightly thinner to preserve the material between the inlet and exhausts in the head), then run a 1.5mm oversized exhaust valve. Inlets I'm going to keep stock.
Does anyone have any advice/recommendations or experience on the subject? I'll update when I'm finished for reference
