Golf 1.8 GTi 8v help
  • Keeper of The Kitten
    • Dec 2003
    • 2317
    A friend of mine has just acquired a Golf 1.8 GTi 8v, and he is flummoxed by two things - I'm not sure either so I'll ask the good people here who might know!
    First up - this breather pipe thing - what does it do, should it be plumbed to something or just open, or plugged?
    And second - this appears to be a sensor, maybe a temp sensor, above the manifold, but it is in mid air and not connected to anything - any ideas?
    Any info appreciated!
    __MDC__
    Martin Cutting
  • saltinot
    • May 2004
    • 1946
    The hole in the fuel distributor (top picture) is the port for the mixture adjustment....which if you were going to mess with it would require a very long 3mm allen.
    The bottom picture I'm not sure of. It looks like the temp switch used on the urq to switch on the injector cooling fan. I don't remember this on my US GTI...sorry.
    Tom
      • Dec 2003
      • 2317
      Thanks!
      Someone else said they don't remember that sensor either?!!
      __MDC__
      Martin Cutting
        If it's Digi then it looks like the temp sender but picture above looks like a K-Jet engine?
        • Rusty
          • 18953
          mk.2 K-jet 8v from the pics.
          • Fat Audi 80
            • 10547
            ....and a bloody mucky one! It wants a clean before you start working on that!
            The Perfectionist
              • Dec 2003
              • 2317
              Lol I ain't touching it!!!! And yes I agree it is dirty.
              It is also definitely a K-Jet, for sure. My only possible interpretation of that sensor was that it might be for cold start/running? I think it looks like a temp sensor and it is in close proximity to (but not actually touching) the intake. Seems strange?
              Anyway thanks for the info so far, if anyone can enlighten me as to what that sensor is for, I'd be grateful. Cheers!
              __MDC__
              Martin Cutting
              • s2avant
                • 2426
                It looks like the rad fan run on switch. They were only used on cars with factory towbars though according to the family album. Has it had a new engine? or head?
                The reason I ask is that those sensors appear quite often on Passat engines of a simlar vintage adn the bits are interchangable.
                Ben
                  • Dec 2003
                  • 2317
                  Interesting!
                  Can't answer if anything has been swapped in, might have to grill the new owner about it.
                  As far as I can tell the connector is broken and therefore the sensor is rendered useless. If it's only for towing options then it won't make much difference, assuming the regular switch works.
                  Thanks for that Ben!
                  __MDC__
                  Martin Cutting
