Alright gents,
A few weeks back my car started intermittently running rubbish, wanting to stall all the time. A quick scan showed 00553 and 00537. Cleared these and away I'd go until it started playing up again. More often than not it's just 00553 that's logged, 00537 comes in every now and again.
Carried out a boost leak, all good.
MAF is a reburbished unit from ECP, a few years old now, possibly around 8, however not done that much miles maybe 10-15k.
Lambda is about 3-4 years old with even less miles, maybe 2-4k.
I was having a read through this for MAF testing-
Basically from a quick check today between pins 1 and 5 I'm getting good battery voltage, around 11.75 with ignition off, with engine running around 12.5 volts.
I then turned my attention to pins 1&3. When the car is running fine with no issues I'm getting correct voltage at these pins between 2.5-2.6v, however when the car is wanting to stall etc there is no reading to be had across the same pins, just showing 0v. Also when engine is off and just ignition feed with no fault codes logged it's showing the correct 1.3v.
Does this sound like my MAF is goosed or should I be paying attention to the supply and ground wiring for these pins?
Cheers chaps.
Cheers chaps.
