My UR-S4 Boost pressure
  • K7ERG
    • 1711
    I was out for a play this afternoon and checking what boost the engine makes i found on the bar digital gauge is was reading 1.9bar holding and sometimes 2.0 for a short period in 5th and 6th gear. Is this right for a standard AAN.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • Knight Rider S4
    • 3541
    Replied to PM Craig take 1 bar off that reading and that should be what you are getting
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • iain1067
      • 984
      sounds about right to me in standard trim
      • K7ERG
        • 1711
        0.9bar or 1.0bar then
        Craig
        07947385043
        • topsparky
          • Oct 2005
          • 2014
          i thought it's supposed to go to 2.2 bar on over-boost on the gauge????
          1. SHORT SHIFT KIT
          2. PORSCHE CAYENNE CALIPERS
          3. H & R SPRINGS
          4. BILSTEIN SHOXS
          5. NEW BUSHES AND HP2 STRUTS
          8. fmic fitted
            Nah it should be more like 2.1-2.2 bar on the UrS4s guage - thats absolute pressure.
            Subtract nominally 1bar from absolute to get boost pressure. The figure quoted above is for UrS4 in factory trim with standard software when its in overboost mode i.e in 4th or higher from 2000rpm then floor it - should see max boost around 4000rpm then it starts to tail off towards redline.
            Max boost not in overboost mode is approx 0.8bar (1.8bar on the UrS4 digital guage)
            Its perfectly normal to see 1.9 on the digital guage if ambient air pressure is low - but not *too* low as the altitude sensor tells the ECU to back off boost so as to prevent the turbo from overspinning in thin air in a desperate attempt to generate boost.
            If you cannot get the AAN or ABY to generate ~1.2bar on factory software then there is a problem... Either the TPS isn't giving a proper WOT signal to the ECU, or there is a small boost leak, or the WGFV is incapable of being modulated rapidly enough to allow that amount of boost to be generated. Other less likely causes are a faulty altitude sensor, faulty MFTS (which is telling ECU that water is too hot and to prevent overboost mode), faulty MAF, faulty MAP (inside ECU) or faulty air or water temp sensors.
            HTH,
            Paul
            • PeteRR
              • 1326
              Hmmm, I've never seen mine go above 1.7 bar on the gauge. Despite just fitting a new WGFV, S3 DV and tightening a loose turbo hose clip that I found.
              I'm betting that there's still a small boost leak methinks. I still can hear a slight hiss under spool-up of the turbo with the window open.
              I guess it's time for the good old pressure test and if needs be maybe a set of Samco's :mischeif:
              But, I did check the throttle travel recently, with the acc. pedal fully down the throttle at the housing can be turned a further 1/4" or so until it hits the stop. Is this normal or should it be right at the stop with the pedal down?
              • topsparky
                • Oct 2005
                • 2014
                mine's the same pete i got a max of 1.9 bar once
                but i can't get it t go above 1.7 bar now
                i'm gonna do a boost leak test when i've got
                time.but try and not blow my maf up
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
                  @PeteRR - yours is automatic and I honestly dont know if they run the same boost profile. If you can send your ECU over I'll certainly investigate FOC - and then we'll know better if that ECU can accept a homefried upgrade as I've never touched an S4/S6 with a slush box before.
                  Your throttle should go all the way to the stop at WOT - if it doesn't then the ECU doesn't think you are wide open !
                  Paul
                  • PeteRR
                    • 1326
                    Though not!, Cheers Paul.
                    I set about getting to the ECU to find the part numbers etc last weekend. Took the panels off to reveal the ECU and low and behold it's actually a Nothelle modified jobby.
                    Trying to find out the spec. now.
                    Though I feel the car doesn't go quite as well as it should (still drives lovely though). 90% sure it's a boost leak.....
                      Ahhhhhh OK - then I imagine 1.7bar is indeed rather low for what they intended. Good chance of a boost leak alright, but tighten your throttle cable 1st !
                      Paul
                      • PeteRR
                        • 1326
                        Will do Paul.
                        I actually set it like that as it was hanging high at idle occasionally due to the cable not allowing the throttle switch contacts to close.
                        I should of just set the switch! Just hoping there's enough adjustment in the TPS to set it, and the cable properly.
                        • adamw
                          • Dec 2005
                          • 348
                          • Country: Shetland Islands
                          i saw 2.2bar about 3 times today!:mischeif:
                          cheeRS adam
                          RS2+
                          • jd2
                            • Feb 2007
                            • 58
                            Before I chipped my s4 I was seeing 1.3 on the digital
                            gauge and 2.0 on overboost.
                            With my 280bhp chips the car hits 1.3 under normal acceleration and 1.7 wot but this is in 2nd right through to 6th and the boost does not back off. I fitted a new boost gauge last week (autometer phantom) which reads in psi, the most I've hit at wot is 10 psi which shows 1.7 bar on the digital display.
                            I had the wastegate adjustable screw freed up last week so I plan to screw it down a few turns and see if I can increase the psi a wee bit
                            100 Avant S4 :bow:
                            HP2 struts with S6 calipers
                            Stage 1 MTM Chips :chit:
                            Stromung Exhaust System :bow:
                            Bosch 005 Fuel Pump
                            Lowered 30/40mm H&R Springs
                            Turbosmart Kompact BOV
                            Autometer Phantom Boost/Volts guages
                            • merlin's S4
                              • Jan 2005
                              • 1539
                              I think you'll find you have a problem! From what you've said your car is running worse performance with the chips than in standard trim! By those figures you're not even running standard boost! You may only be running mechanical boost which is determined by the wastegate spring alone. Is your wastegate frequency (wgfv) valve plugged in? Winding up the wg spring is not gonna help you one bit!! With so called 280bhp chips I would expect you to be seeing up to 2.4 on the digital guage! Whose chips are they??
