i think my head gasket is knackered
  • topsparky
    • Oct 2005
    • 2014
    is there anyway i can check this
    there's no mayo or gunk in the expansion tank
    none on the dipstick
    it's using from max to min in approx 600 miles
    can the system be pressure tested at home/diy
    any help cheers guys
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
  • PeteRR
    • 1326
    Are there any traces of coolant on or around the expansion bottle?
    My expansion bottle cap failed recently and coolant dumped out through it when hot after the engine was stopped. A new cap obviously sorted that.
    Though in fact there's still a tiny leak from the small hose outlet of the bottle I think. I've got a nice new bottle to fit when I do my coolant any time soon.
    Otherwise, can you see any bubbles in the tank when the engine's running?, any water vapour from the exhaust when the engines hot?
    You can pressure test the cooling system with the engine hot and turned off using a special pump that fits in place of the cap. Not sure how much they cost though.
    Or a dye kit that tests for combustion gases in the coolant might also tell you if there is a problem.
    Hope it's something minor like the cap though.
    • topsparky
      • Oct 2005
      • 2014
      on start up in the morning there's a lot of grey/white smoke
      i might have to take it to a garage me thinks
      1. SHORT SHIFT KIT
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      8. fmic fitted
      • PeteRR
        • 1326
        That could be just normal condensation, but it's worth getting it check out just in case.
        I'd imagine it would misfire noticeably if coolant was laying on top of the pistons overnight.
        • topsparky
          • Oct 2005
          • 2014
          Originally posted by PeteRR
          That could be just normal condensation, but it's worth getting it check out in case.
          cheers pete
          yet more expense
          who said owning an audi was easy
          on the other hand the thrills out way the costs
          imho
          1. SHORT SHIFT KIT
          3. H & R SPRINGS
          4. BILSTEIN SHOXS
          8. fmic fitted
          • s2_bo
            • Oct 2005
            • 6067
            Originally posted by topsparky
            cheers pete
            yet more expense
            imho
            Good Luck with this mate... - I hope it turns out to be something simple...
            Cheers.
            Bo
            91 S2 coupé - RIP
            98 S8 - Luxury barge
            • blown_vr6
              • Apr 2005
              • 406
              Does it start up on 5??
              Sure sign that the H/G is gone between the waterway and the combustion chamber is starting up on 3 or 4 cylinders when cold.
              Coolant forms in the combustion chamber as the cooling system is still pressurised, as the engine cools down this leaks through the HG.
              'If you ain't broke it you ain't trying hard enough'
              Oh sh*t i broke it
              94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
              • topsparky
                • Oct 2005
                • 2014
                it starts up 1 st time every time
                i'm getting a few niggles at the moment
                amber battery indicator comes on every know and then
                red brake pressure indicator comes on when i set of fast or go round a bend
                all fluid levels on p/s and brakes are max
                it's just cheesing me off
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
                • Condor
                  • Jul 2004
                  • 424
                  Water loss.
                  Just a thought, have you checked around the area of your heater matrix for a leak, ie maybe damp carpet ect, just a thought, try the simple things first before you take it to that expensive garage good luck...
                  :wave: :thumbs:
                  • WabTheKing
                    • May 2004
                    • 2567
                    alternator needs servicing
                    dodgy switch on top of hydraulic fluid pot
                    you need to do a compression check
                    • PeteRR
                      • 1326
                      Originally posted by WabTheKing
                      ..dodgy switch on top of hydraulic fluid pot...
                      The 'plunger' on my hydraulic fluid reservior cap was a bit gungy, which may potentially cause it to stick occasionally and flash up the warning.
                      I cleaned it with an old toothbrush and a very small amount of WD40.
                      • pastures16
                        • 2058
                        oh!! blown a gasket
                        thought mine had gone look for leaks mate no matter how small a coolant pressure test might help
                        mine was a slightly leaking rad and after run pump
                        if its running fine it wont be the hg mine smoked when i decated
                        94 s2 avant
                        aoc member 1116
                        • S-Express
                          • Nov 2006
                          • 1133
                          Cylinder leak down test is the best option (£40 ebay)
                          This will tell you how much air is escaping from your cylinder and also where its going - so you'll know if its rings / head gasket / valve stem seals etc.............
                          • pastures16
                            • 2058
                            if its the bluepoint/snapon dont always work
                            94 s2 avant
                            aoc member 1116
                            • GT500
                              • Jun 2006
                              • 2181
                              I'll swap ya for my knocking noise!!!
                              Just opened vino number 2. Chuffin cars!!!!!!!!!!!!!!!!!!!!!
                              Rob..
                              87 UR 20v ABY
                              97 S6 Avant
