Valve guide replacement cost
  • Palin
    • Aug 2021
    • 45
    What would be a baseline cost to replace the valve guides in an AAN/3B head if supplied the loose head and guides + the valves?
    I.e only the labour.
  • SteveH
    • 4460
    That's really going to vary on who you use to do it mate. I had some of mine on an old 3B head reamed out and some form of spiral insert was used. The machine shop recommended this over replacement as they said the inserts were better material. Think they were £15 each. I think some folk have found the items supplied as replacements by some vendors don't have the step on them too. Worth checking before purchasing.
    91 Modded 3B
    14 A6 Avant Black Edition
    • SteveH
      • 4460
      I believe it was the K-Line inserts the shop used.
      91 Modded 3B
      • Palin
        • Aug 2021
        • 45
        https://www.hthoward.co.uk/engine-ma...uide-sleeving/
        Hmmm! Thanks for the tip
        • Bowie69
          • Nov 2013
          • 2675
          Yes, very common, and a good solution, can mean minimal valve seat cutting.
