Finally got a chance to work on the RS2 today. I was able to get the electric fan and shroud out after some tweaking. It is so close to the ABS lines but after loosening the front radiator support I was able to maneuver it out of the way. Then you have better access to the sensors which are a pain in the *** to get to
I ended up using a "Crowfoot" wrench in order to get in that tight space. It worked very well all things considered doing this job. I'm sure they got these in the UK, right ?
After getting everything back together, my hot idle pressure is still at 1.0-1.1 bar on the gauge but it seems as though the warning message is now gone. I was only able to run it for about 30 minutes with only a couple trips around the block but it seems to be fixed as no buzzer or light ever came on.
Both sensors that were in there were FAE brand so they must have been replaced at some point in the past. That was pretty much all I could replace them with so let's hope no future problems. Lord know I do not want to take this apart again
Thanks again for all the help with this, appreciate all the support.
