leaking turbo????
  • topsparky
    • Oct 2005
    • 2014
    leaking turbo????
    it possible when doing a boost leak test that air can escape thro the
    compressor housing???
    i have tightened/renewed all the hose clips and pressure tested upto 1 bar
    there is a hissing noise from turbo area but can't get my hands near the hose to put
    any soapy water near it??
    i have also removed the dv and plugged the hoses
    because i think this is leaking aswell
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
  • Crawford_S2
    • 1555
    Could it be possible the air is getting past the seals and escaping down the exhaust? Not sure but think they are designed to work with pressure on both sides i.e. oil pressure workin against air pressure. With the engine not running oil pressure would obviously be 0. Just a thought.
    Ragusa Coupe gone!
    • topsparky
      • Oct 2005
      • 2014
      cheers crawford going to put it all back together
      test it again and see what happens
      i feel the f.m.i.c and turbo upgrade coming on sooner than i though
      1. SHORT SHIFT KIT
      3. H & R SPRINGS
      4. BILSTEIN SHOXS
      8. fmic fitted
      • topsparky
        • Oct 2005
        • 2014
        well put everything back together and adjusted throttle cable a tad
        now seeing 1.9 bar on boost gauge still sounds like i have a boost leak
        as you can hear the turbo spooling up.
        just a bit ****** off the allthe problems @ the moment
        but with a bit of faith and some hard work
        oh and a 5h!t load of money should get it sorted
        ooh got around the censor bit aswell
        1. SHORT SHIFT KIT
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        8. fmic fitted
        • pastures16
          • 2058
          i thought that was normal now you got me thinking ive a leak if you need to borrow a turbo i have one spare
          94 s2 avant
          aoc member 1116
          • topsparky
            • Oct 2005
            • 2014
            cheers mate fancy coming up and help me fit it as well
            beers in the fridge and all that
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • pastures16
              • 2058
              ill wipe your a** aswell
              not
              94 s2 avant
              aoc member 1116
              • topsparky
                • Oct 2005
                • 2014
                not
                cheers you must know i get frozen shoulders
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
