Hi
Will be doing a rebuild on my 3b engine with the standard uprated rods etc.
Considering to changing out the turbo with still keeping the original look;
Been reading several posts regarding the K26/GT2871 which seems like the solution I might be using.
How is it with surging on a rather stock setup with stock cams on the 3b engines (2.2) ?
Will it be too hot over a long period of time?
What can I expect form a KKK/GT2871 compared to a RS2 hybrid or the turbo im currently using (k24 7000 hybrid).
Where can I expect spool up + max boost ?
Or would a KKK/GT3071 be a better solution?
The ideal goal for me would be a fast spooling 420-440hp crank setup for driveability.
Currently got a Wagner em (kkk flange), currently stock IC which will be changed, injectors will be changed, running custom ecu,
already got a 3" exhaust and downpipe will be made. Feel like this would be a nice solution, if there will be any problems at "MOT/TüV" it would be easy
to swap out the turbo for the original unit..
- Lars
- Lars
