AAN cam position sensor
  • Mzx944
    • Mar 2022
    • 53
    Hey guys
    Does anyone know of anywhere that has the AAN cam position sensor in stock in the UK (or further afield if required)
    OE part no. is 034905161
    Max
    Sent from my SM-G973F using Tapatalk
  • Rikki Kitto
    • Feb 2010
    • 6276
    Ultra Performance Engineering, Error 404 on here
    • Mzx944
      • Mar 2022
      • 53
      Looks like they're out of stock on the website
      Will see if I can get hold of him through the forum - thanks
      • Rikki Kitto
        • Feb 2010
        • 6276
        I sent him my knackered one and he used the bracket and fitted a new one to it, I think he is just waiting for brackets but has the sensor
        • Maiks2
          • Mar 2012
          • 7
          send me pm, i have a cheap alternative.
          • Mzx944
            • Mar 2022
            • 53
            Bumping this - still looking for a replacement cam pos sensor (OE part number 034 905 161
            Tried ultra performance with no luck and not come across anywhere else with one in stock, all have lead times unfprtunagrly
            Does anyone on here have one available?
            Max
            • Rikki Kitto
              • Feb 2010
              • 6276
              Did you message Error 404 or just check the website
              • Mzx944
                • Mar 2022
                • 53
                Both - didnt hear back on here
                A chap called Alex from ultimate performance said they would email me once available again but havent heard anything so far
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Alex is error, email him on the website ask if it's possible to send yours in like I did, it's worth a shot bud
                  • Audicted
                    • May 2004
                    • 366
                    • Home: Jamaica Current: United States
                    Try Mark at efi express, he's here in the USA I got mine from him late last year https://shop.efi-motorsport.com/
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Think the efi ones are almost double the price but if you need it you gotta pay like all parts for our cars now getting even more expensive keeping them going, import tax on too too probably
                      • KWracing
                        • Dec 2025
                        • 2
                        There is also a cheaper solution. Just replace the sensor itself. Volvo part (oem1346792 ) will fit directly to Audi sensor bracket and wire colors are the same.There are also many aftermarket makers.
                        EPS 1.906.222 , Vemo V95-72-0038 , Hitachi 138154. I replaced mine with Facet 8.2722
                        • Alex20v
                          • Mar 2015
                          • 22
                          • Home: Russian Federation Current: Germany
                          Wow cool
                          and how is it about the lenght of the cables?
                          • KWracing
                            • Dec 2025
                            • 2
                            Originally posted by Alex20v
                            Wow cool
                            Lenght is more then enough. You need to cut the original wires anyways to make it correct lenght.
