leaking rad?
  • missmouse
    • 296
    leaking rad?
    anyone know if you can replace the main rad without losing the a/c gas? (due to the fact the condenser is bolted to the rad) Mine is f****g leaking!
    Simon
    '93ABY
  • MidnightBlueS2
    • Jul 2005
    • 1653
    • Home: United States Current: Belgium
    Simon
    '93ABY
    Yes, no problem...
    And as a precautionary tip, have a spare gasket handy for the lower main rad thermocoupler coz sometimes, the original gasket shears when removing the rad.
    2 hour job though...
    Midnight Blue S2 - SOLD - 1993 S2 Avant
    • Fat Audi 80
      • 10547
      As David says, IME you need to have some string on a bungee handy to "tie" the AC rad out of the way once you have unclipped it from the main rad etc.
      But yes it is possible without a re gas but I would allow 4 hours
      cheers,
      Steve.
      The Perfectionist
      • Briggsy
        • Jul 2005
        • 267
        no problem at all, like every one else said its a time consuming job!! bungee not essential but would be a great help!!
        if you are replacing the current rad with a Nissens then take the time to re-tapp all the mounting hole's around the edge, will save swearing and time!!
        1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
        2001 P38 Range Rover DHSE 159bhp and 255lbft
        1985 Type85 Audi 90 quattro 135bhp 140lbft
        • missmouse
          • 296
          thanx
          thanx for the tips guys, one more thing, where is best place to get new rad? I was thinking of a re-core from serck but if likes of GSF or VAG parts do complete new units for reasonable cost.........?
          Simon
          • Briggsy
            • Jul 2005
            • 267
            if you buy from GSF its likely you will get a Nissens, i personally haven't had any problems with them but some people on here wouldnt recommend them. Think they are around £110 from GSF, but not sure how much from VAG, maybe worth a phone call.
            • Dpicariello
              • Mar 2006
              • 621
              I got mine re-cored for £100. Ended up being a lot heavier (it's now a copper and brass core) but I got a 2 year guarantee with it and so far it's been fine.
              I'm going to do the same with my aux rad when i come to do my next coolant change as all the fins are falling out!
              • Briggsy
                • Jul 2005
                • 267
                Dpicariello, have you got any pics of the re-cored rad?
                how long did it take them to get it back to you?
                Jose.
                • Dpicariello
                  • Mar 2006
                  • 621
                  Not got any pics of the rad whilst it was out, should've taken some I know. I can get one for you as it sits in the car but to be honest there's nothing particularly different about it.
                  The chap did mine in a day, he was very good. It's worth replacing the 3 rubber mounts (bottom, side and top) as well but these are about £3 from GSF.
                  • Briggsy
                    • Jul 2005
                    • 267
                    i should have kept my old rad and got that re-cored........!
                      Depends on where you rad has failed. Most common failure is the plastic end tanks in which case the rad can't be recored.
                      • Briggsy
                        • Jul 2005
                        • 267
                        in that case i done the right thing............binned it!!
                        thanks jamo.
