Car Won't Start
  • Nathan94
    • Dec 2022
    • 96
    Car Won't Start
    Went to take the car out this morning and crank and no start!
    Up until this point the only issues I've had is 10psi of boost and hunting for idle when slowing down.
    Other than that seemed and sounds ok so a bit sad!
    Best places to start looking?
    • Dec 2017
    • 5983
    Lots of good threads on this subject on the forum by one by Dave is a good place to start.
    • Michael S2
      • Dec 2011
      • 1378
      It will likely be something very simple. Just have a good search of the forum as there's plenty of "no start" threads on here. Comes with the territory of owning one of these great cars, they will test you now and then though.
      1995 Audi S2 Avant
      • Nathan94
        • Dec 2022
        • 96
        It did sound like it wasn't cranking overly fast and looking through invoices the battery is a platinum brand which is 5 years old, as far as I know these aren't great.
        I'll try jump start it later and see if it is just the battery. It is completely flat now after 3/4 lots of cranking for 20 seconds. If it starts off a jump off to Costco for a new battery, if not back to the drawing board!
          • Dec 2017
          • 5983
          Be careful jump starting. Don't use one of those boosters. Some have fried their ecu's using them. I would trickle charge your battery overnight.
          • Nathan94
            • Dec 2022
            • 96
            So, got home and it's just started now...
            Could the ISV cause no start? Or maybe the cold this morning upset the battery.
            Im going to order a 2x2 ​to obd anyway and see if thr ECU has flagged anything.​
              • Dec 2017
              • 5983
              If the battery isn't 100% slow cranking will cause a non start on the S2.
              • Nathan94
                • Dec 2022
                • 96
                Well I've just seen it's 2017 written on the battery and it is platinum brand, plus batteries not liking cold and not cranking fast enough could be the answer.
                Given the age and the fact it isnt the best brand I might just swap it for a Bosch one for peace of mind, I've known cars act strange in the past when batteries start to die.
                • K Simmonds
                  • Dec 2007
                  • 7627
                  Sounds like you could do with a new battery regardless if it only managed a couple of burst's of 20 seconds crancking and yes a dying battery could well be the cause of your problem, it has to reach a certain RPM before the ECU let's it start.
                  Has the car got an aftermarket alarm/immobiliser fitted? They can often be the cause of starting issues and are pretty pointless as they can be bypassed in minuets, if it has I'd do away with it before it strands you somewhere.
                  Do you have VAGCOM? A ripped copy of that along with a cable is pretty much an essential tool if you own one of these cars, takes most of the guess work out of finding faults and costs very little these days...
                  I ask as there's a couple of other things that spring to mind that can cause random non start's, a dying cam position sensor being one the other being the coolant temp sensor on the back of the head which is what the ECU uses to control the warm up enrichment cycle.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • Nathan94
                    • Dec 2022
                    • 96
                    I've just ordered the 2x2 adapter to use vagcom.
                    I was wondering if the temp was over reading as it idles at 3 notches above 90c but then drops to 90c when moving.
                    I'll swap the battery and see how I get on, it did sound like the crank wasn't as fast as I'd expect.
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      Cool, VAGCOM is really an essential bit of kit when running these cars.
                      A good mod is cut out the hole in the drivers side under dash trim that's outlined on the back for a footwell light and fit the OBD II connector end of the adapter there. Unclip the 2 x 2 connectors from the fuse box, feed the wires down and connect them to the other end off the adapter, wrap the joint in loom tape and refit the trim. Then you plug the VAGCOM cable in just as one would on a more modern Audi, of course you could do it permanently with solder and heat shrink but that isn't so easily reversible should you ever want to put it back to stock...
                      The temp sensor on the head isn't connected to the gauge in the car, that gets it signal from the MFTS, the one on the heads sole job is to tell the ECU what the coolant temp is so your gauge reading won't be connected to the non start.
                      As you say fit a decent battery and see how you get on, hopefully that'll sort it... I can't recall the RPM required off the top of my head but if it's only turning over lazily then it won't be getting fuel or spark.
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • Nathan94
                        • Dec 2022
                        • 96
                        Will an 096 battery fit in the avant or am I better sticking to 100?
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Bigger the better
                          • Nathan94
                            • Dec 2022
                            • 96
                            Originally posted by Rikki Kitto
                            Bigger the better
                            Cheers, it's slighter taller so would that pose an issue?
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              I went for the biggest amp battery that would fit In the tray mines under the back seat
