I've decided that upgrading the ignition system on my WR is the best way to go with it. On K-Jetronic it has been unreliable at best.
So I'm looking at a MaxxECU conversion. I have Performance Vehicle Engineering lined up to do this as Steve there knows his stuff and has converted a few now. One of the projects he has worked on is documented here: https://www.p-v-e.co.uk/work_blog/jamies-quattro/
But I wondered if anyone on here could advise of any off the shelf/custom items that I could source to keep costs down to a degree or known easy modifications that can be made to the hardware to suit the MaxxECU.
The main hurdles are a crank position sensor and TPS sensor. So if anyone has any pointers on these please let me know.
I already have the following which I plan to use:
3b airbox
ABY or 440cc injectors
034 WR spec fuel rail
Any other tips would be much appreciated.
@Alex/Error404 apologies if you see this, I know we have spoken about a lot of this but I have a memory like a sieve!
3b airbox
